Results 1 to 8 of 8
Thread: saginaw oil
    Apr 2010
    129
    Default saginaw oil
    what gear oil is best to run in a Saginaw for a 1/2 mile dirt track
    automatic transmission fluid
    in a van down by the river
    1,892
    Default oil
    Quote Originally Posted by ric78 View Post
    I think that depends on what bearings are in it doesn't it.
    I would think you would need 75/90 gear oil for most units.
    Just a stock saginaw 3 speed we have ran them with just ATF for years never a problem. A transmission run through high gear does not generate enough heat to hurt anything.
    tulsa america
    2,686
    Don't you need the GL rated stuff for the brass synchros? I think its a gl-4 if my memory hasn't failed me. Or are you saying because its not shifted much you don't need that?
    Never looked at that just used a good name brand. Years ago I was mixing it half gear oil half ATF. Then just decided to try straight ATF and never looked back. Maybe we were just lucky. All I know is for five years the only trans problem we ever encountered was a broken ear.
    Nov 2007
    205
    Synchros actually like the atf better. shift quality may suffer with 80/90. As if that were a concern in our app. Have ran same oil as engine with no problems. Currently running 85/140 same as diff after learning from oil supplier that 15w40 and 80/90 start from same base oil. additive only difference. 12th year on same trans. Biggest thing is keep some in there. with atf and engine oil, cheap insurance to change same as engine.
    1,289
    Synthetic ATF in anything from a stock unit to one built with ceramic bearings. I prefer Dexron hp.
