Block decking ?
I recently got a motor built by someone I wasnt familiar with and so I took the head off. Im new to working on engines so I dont know if the blocks been decked or not....do I need to measure the piston pop up and is there a way to look at the block to tell if its been done...there are large swirl marks going all the way across the block but hard to tell with my lack of knowledge
If it looks like brand new metal it's probably been decked
It does look new but Ive seen alot of motors that look new but have couple seasons on them...wasnt sure if there were any markings I can go by or check piston pop up
lay a straight edge across the cylinder with the piston all the way up and see what feeler gauges fit under there if any
www.raceidaho.com
if the swirl marks are there, will that be an indication it was decked...its not legal in my class and can't afford a new block....
i use a flat file on the deck of my blocks just to clean them, and it leaves swirl marks
www.raceidaho.com
