Results 1 to 4 of 4
    May 2012
    334
    Default Question on bird cage
    put new keisler steel bird cages on our QC and lost forward drive and side bite. center or tube to hiem is 3/4 inch shorter than our old ones but that should just speed them up not loose traction. any one have a problem with these cages.or now how to fix them.
    Jun 2007
    Nebraska
    393
    The only way to get the car back to the way it was before is to move the 4 bar location on the birdcage as well as the spring and shock mounts on the birdcage to the exact same location as they were on your old birdcages. Motion ratio's of your birdcages make a huge difference in handling.
    Nov 2007
    509
    It could have added more rear steer when on the bars.
    May 2012
    334
    thanks that is what we were thinking. our old cages were custom built and did not have the time to build another set but did find some new one that check out the same as our old ones. we will see this weekend
