Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Quote Originally Posted by a25rjr View Post
    front 1-1.5"rear 2.5-3.5 depending on what tire rules you run, generally 3 is all u can get
    I'm on a DOT tire so that's doable. Seems like some guys in my area are only running front stagger. Why is that?
  2. #22
    in a van down by the river
    1,892
    front stagger means nothing really, because the 2 tires are not connected together and pulling. bout the only thing it does is give you additional ride height on RF, and will adjust wedge.
    Just My opinion tho.
  3. #23
    Sep 2007
    208
    is front sway bar tight r to left car needs to fall on left front going in, start to rotate just before middle
  4. #24
    Feb 2016
    The land of Irma
    3,774
    Quote Originally Posted by Hodrod7 View Post
    Probly means that is the only way they could get their car tight enough. That's a poor way to do it and never the best way.
    Turn LEFT, Vote RIGHT!
  5. #25
    1,892
    possibly need to take out anti -dive out of the left front upper a arm. this should help it fall on the lf harder and steer better.
  6. #26
    Feb 2016
    The land of Irma
    3,774
    You probly know this but put the biggest tire you can run on the rr and go from there.
