Carb Help
I have a Holley 4412 Carb that when i go into turn and pick up throttle it cuts out until I start going straight again than it comes out of it, I though it was float level but it is fine. any ideas what may cause this? It also seems like the longer I run the worse it gets, and i swapped carbs out with another one and it quit so I know its the carb
