Results 1 to 4 of 4
Thread: 03 04 bms help.
    mooresville nc.
    121
    Default 03 04 bms help.
    I have an 03 or 04 bms and need some setup help. Tried calling bms and didnt get answer even emailed with no responce. Metric clip metric lowers pinto spindles 9" rear end came with rubber bushing pullbar and big spring pullbar. I need help with springs shocks j bar wheel offsets ls weight rear weight lr bite and weight placement. It my sons first car he is going to put a 602 engine in it. Any help is appreciated, thanks.
    Sep 2012
    127
    Check you pm.
    Call close racing supply814-225-3250They specialize in bms and get chassis
    BMS is now in Great Bend, KS, under the same roof as Xtreme Motorsports. Call (620) 796-2290 and talk to the guys there. Mike is the shop manager and Jimmy is the guy building the BMS cars. I have been working with them with great results
