Gears/Springs/Bert trans and Misc parts
Winters gear sets #1 4.11/4.86. Set 10 5.57/6.57. Set16 5.49/6.48. Set22 5.42/6.39. Set23 5.18/7.29. Set24 5.97/7.04 Set27 6.37/7.51 Set28 (New) 6.51/7.67. Set29 5.59/7.77 Set35 5.82/6.86 Set36 6.06/7.14 Set50 (New) 7.21/8.50 $30.00 Used/$50.00 New. Bert Ballspline Mag Case 350 laps since rebuild $1100.00.8" Swift 300# spring, 10" 400DLC Integra spring, 12" 225/250/275/300/325 Swift springs, 12" 350/400DLC Integra springs $45.00ea. 2 Ohlins STJ torque arm shocks $250.00ea.37 1/2 Wiles carbonfiber drive shaft fresh back from Wiles, has slight rub mark on it but tested OK $300.00. Set of 4 steel roll off scale pads used once $350.00. Collapsable steering shaft from Mastersbilt $250.00. Sweet aluminum power steering pump with V-belt pully $125.00. 10 Integra Stealth shocks with coilover kits 7" and 9" some are basevalved $100.00ea. Sanborn air compressor used little $250.00.Masterbilt spindles $50.00 ea Call 402-379-2230 8-6 M-T or call or text 402-640-3996
Pic of Bert to 805-260-1628
To the top. Integras are sold.
Integras, Bert, Driveshaft, Ohlins shocks sold
Integras,Bert Driveshaft, Ohlins and mastersbilt spindles sold
toppppppppppppppppppppppppppppppp
Mastersbilt spindles still available deal fell through
what kind of mastersbilt spindles?
Topppppppppppppppppppppppppppppppppp
Most of the gears, roll off stands,air compressor, and spindles left
