Results 1 to 3 of 3
Thread: Bert troubles
    May 2011
    North Carolina
    57
    Lightbulb Bert troubles
    Guys I need some help. I'm having trouble getting my transmission out of low and into high. I've replaced the shifter fork, the shafts and installed the new piston type deal that replaced the old rubber brake cup. I've adjusted the linkage every way but just throwing them away. Lol
    With the engine running sitting at idle I can get it in and out of low very easy but when I start rolling like normal and go to shift it will not move until you just stop.
    Any one ever had anything like this happen?
    If your not racing on dirt it's your on asphalt!
    Just had the same problem, my reverse idler gear broke in half. I would also check that it wasn't installed backwards as one side has a lead in on the teeth and the other side doesn't.
    May 2011
    North Carolina
    57
    I'll check that too . Thanks
