Results 1 to 4 of 4
Thread: ohlins shock
    Jul 2014
    8
    Default ohlins shock
    Can not feel the clicks on rebound adjuster.. is there any way to fix this without sending shock off?
    a lot of times comes from dirt getting inside the adjuster. take heim off end and clean. should fix the problem
    Jun 2007
    3,123
    It's normal from them to do this occasionally when there is no load on the shock (fully extended). Also be sure that you have gas pressure. But you could have some dirt or debris inside the adjuster knob that is keeping the pin from moving down. Take it apart. It's a pretty simple setup. Here's an exploded view if you're unclear on how it works:
    http://www.resuspension.com/assets/L...on%20Shaft.pdf
    Jul 2014
    8
    thank you for the help...i will get it done
