Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Nov 2007
    509
    For a push from center off I would raise the RR front bar.
  2. #22
    RCJ RR front bar all way up only have one hole for it
  3. #23
    Apr 2015
    234
    Sounds like u have a little to much drive something needs dun in the rear not front
  4. #24
    Nov 2007
    509
    Well that makes in more difficult.Might take a little crosswieght/left rear out of it.Finding a change that effects corner exit and doesn't hurt you any where else is the hard part.
  5. #25
    474
    If slightly tight off is the only issue, roll RR back 1/4" at a time till you get what you are looking for, or increase stagger 1/2" at a time.
  6. #26
    Would you stick with current springs had suggestion of putting 550 on rf and 600 or higher on lf
  7. #27
    Nov 2007
    509
    If you like how it is getting in and thru the middle I wouldn't change front springs.The l/r has more grip than the r/r causing a push on exit.Ideal you would like to balance that, the bars would be one place to change with small impact to the rest of the corner,No adjustment left there.L/r bite would be the next place to look,rear steer next, only because it will have more effect on the rest of the corner.You might change the location of the rear end ,move it to the right 1/2'' but I can't give much input on how big of a change that would be.
