Chevelle or Metric?
I know this is mattter of personal prefference, but was wondering which front clip ona mod is the easiest to set up for a best geometry? and stability and strenght, and available parts? between a metric front stub or chevelle, Which top name builds a good metric, and which a chevelle. thanks...
The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
Go chevelle. 90% of the cars are chevelle. Trust me.
I would use a OEM frame if you can find a Chevelle go that way but if you can not then go metric . Both metric and chevelle stubs have the same good points and same bad points .
early 70's Monte Carlo as well.
same points as a Chevelle but more tire clearance in the elbow.
I prefer Metric chassis myself, and if you are allowed to run tubular lower a-arms I would use a Lightning or Ruhlman Fold Crown Vic lower.
How much wider does the Crown Vic make the metric car with nova lowers currently?
Thanks to all.... It helps a lot
G.K. Chesterton
Originally Posted by let-r-eat
Newer Caprice clip.
Like what year? who builds a good metric frame chassis? i know several build chevelle.. does Impressive use chevelle?
G.K. Chesterton
Metric
I have a Bandit Metric that I have had for a few seasons, and im pretty sure they will still build metric cars.
other options would be Lightning, ruhlman, diamond(not sure he still does them) and pierce. Those are probably your most popular/best options on metric cars.
I have a Lightning, so I am partial to them.
Ruhlman is also has a good front end design.
Bandit's aren't bad either, I think they are building a lot of Chevelle's now
Stay away from Pierce, not a good design, or redesign.
just looking for the best front end geometry i can find, i know there are alot of good stuff out there. and was wondering if the chevelle to metric. I thought Diamond was chevelle?,,, I didn't even know you could use ford lowers on a metric clip.. Can you use them on chevelle? and where do you get them? our rules allow tubular lowers. Again thank you for all the info.. keep it coming.
G.K. Chesterton
Where can a person get a good system or artical on when and what to change, to fix front end geometry. i know enought to be dangerous. which is little..
G.K. Chesterton
The problem is not whats right or wrong, works or doesn't, but what design fits the rest of the car. Balanced handling is what your looking for and the means you have to look at the entire package including the driver so theory is about all there is.
If you want one of the best front ends out there talk to Mark Bush Racing. Bring your checkbook
MB front ends aren't winning as much as others. Just sayin...
Originally Posted by old fan
better get a impressive
They chevelle or metric? Thanks to all that have replied again.... Just tying to make a decision, I heard someone was stamping chevelle fronts wasn't sure if it's true or not.... Thanks again..
G.K. Chesterton
I have an ELITE Chassis, Chevelle front end, Yes its a new re-stamped Front clip, hard to get a factory metric or chevelle that isnt half way rusted from the inside out. What people are trying to tell you is this: You cant just go throwing longer arms and a bunch of crap on any clip and be fast. Lots of things will change, spring pocket locations, spring angles, RC, camber gain, ETC ETc. You have to know what you want and why you want it before you start. Our ELITE has a very good front end, but my driver needed it to work differently so I re designed the geometry to work with his driving style, not against it. I wanted the the front RC to be in a certain place statically and move to where I wanted it dynamically based on what I saw the car needed, Same for camber gain, etc. It ended up working very well. Is there 1 book that spells out exactly what to do? lol NO. This information is very hard to find. Lots of info explain static geometry but dynamic is where its at and very limited info in print on that.
Dave
Dave
Thank you.... I totally understand
G.K. Chesterton
