Results 1 to 6 of 6
Thread: sbf on alky ??
    Jul 2008
    253
    Default sbf on alky ??
    Any one else running a sbf on alky and if so what fuel pump setup are using ?
    Jan 2009
    12
    a friend of mine when she ran a modified and a sbf ran a kse belt drive set up
    Dec 2008
    thedirtysouth
    4,019
    were running a holley 2brl on e85 on a 351 with a holley traditional pump that will pump alky or gas. this is on a street stock. now i know some one that is running a stock pump on a chevy with e85 and says its fine, but i would think it will eventually get the diaphragm or a check valve , but hes run it all year so far......
    Dec 2008
    thedirtysouth
    4,019
    Quote Originally Posted by grtmod3d View Post
    just curious, was she from Mississippi and use to come to the ice bowl?
    Oct 2010
    422
    KSE Tandem on ours, also ran a belt drive BLP fuel pump. Both worked well.
    Jan 2009
    12
    yes she origanlly use to be from mississippi and then moved to north carolina
