Results 1 to 6 of 6
Thread: Stagger?
    Oct 2007
    205
    Default Stagger?
    What would be a ball park start with stagger, frt. and rear, on a high bank, dry 1/4 ml track
    Batavia, OH
    13,631
    Quote Originally Posted by ace1 View Post
    Corner radius is the most important factor. That said, 1" in front and 4" in the rear is never going to be totally wrong.
    Florence -1
    Oct 2007
    205
    Its a sweeping turn on the gas track. What would be some roll out on the tires be. I have to swap some tires around but at the moment I have right sides at 91 1/2", lefts at 86 1/2. I have to learn what number size tire goes where. The latemodel tires are a new thing for me. Thanks
    Batavia, OH
    13,631
    Most run 28.5 diameter on the front and lr. Bigger chalk marks on front.
    88 or 89" on front.
    87 lr. 91rr
    Florence -1
    Dec 2007
    662
    We use the 91/s on RR RF LF 86 LR mainly to carry less tires all 3 tires are nearly the same size offsets are the same we always put tire we take off on LF saving a little money that way.
    Jul 2014
    455
    We usually start about 1/2 to 3/4 across front. And about 4 1/2 to 5 1/2 across rear. We run a tight corner high banked track
