Results 1 to 10 of 10
    Feb 2009
    470
    Default engine stumble at higher rpms
    This past weekend I experienced my engine stumbling as I approached higher rpms. For example, when I shift into high gear I rev the engine to 3000-3500 and it wants to stumble and quit. Also when I clear the carb it wants to quit.
    Fuel pressure is 7 pounds
    running 93 octane 604 crate
    Could it be the plugs? it is hard to start at times.
    Jun 2007
    570
    sounds like a carb issue,
    Feb 2009
    470
    I plan on this week having the carb gone through, as well as changing the fuel filter, and spark plugs. If its not these three Id imagine maybe a fuel pump or battery voltage issue.
    I was just curious if anyone else has had this type of problem?
    Illinois
    1,690
    Yes, had this same issue on a friends ministock opening nite, removed the fuel filter (was full of deteriorated fuel cell foam) and problem solved!
    Feb 2009
    470
    I changed the fuel filter and the spark plugs. I'm gonna see how that goes this Saturday, if it doesn't solve it my next step is to look into the carb and fuel pump.
    I'm also going to check and make sure I'm getting the proper voltage.
  6. #6
    in a van down by the river
    1,892
    check battery with a voltmeter now. should be more than 12 + volts
    check while it is running should be 11-12
    11 being lowest
    have another battery ready to try.
    does motor crank /start easily or is it sluggish?
    Where your old plugs black and sooty? If so you may be rich on fuel mixture.
    Was system ever dynoed, chassis or engine?
    could be a coil breaking down as well.
  7. #7
    Jul 2007
    3,224
    Quote Originally Posted by racinjason29 View Post
    no chassis dyno within a few hours of you? a chassis dyno is a lot cheaper than towing to a track and having poor results week after week
  8. #8
    Feb 2009
    470
    The plugs were black and sort of sooty. Looks like it was a little rich. On starting it isn't real sluggish but it does take it several cranks to get started. I was going racing this past Saturday to test it out but we got rained out
  9. #9
    Default power valve
    the power valve in your carb is bad --or is the wrong size
  10. #10
    Dec 2013
    maryville tn
    149
    Possible power valve in the carb, change the coil just some ideas
