2015 Warrior Crate Car
Selling in a few different options:
Car:
2015 Warrior Race Car
30 laps on the car. Not finished until 2016.
Tall Cage, adjustable front upper control arm mounts, semi flat black powder coating
Everything was new on the car other than the motor. No expense spared.
Includes:
CVR flat black body, 8” and 12” spoiler. Black MD3 nose, with white trim.
Fluidyne Radiator
Sweet Rack with Sweet collapsible steering column and Longacre suede steering wheel
All FK Rod ends
Most fittings and all lines are Fragola.
Aeromotive fuel system (filter, telescopic log, regulator with return to fuel cell)
Fuel Safe fuel cell (17 gallon)
Bert magnesium bellhousing
Powermaster starter
The Brake Man brake system
Sweet reverse mount power steering pump with Waterman fuel pump
All Howe Uppers and balljoints
DRP scalloped tubes
DRP lightweight axles
Winters magnesium hubs
Timkin bearings with DRP bearing spacers
BSB double sheer birdcages
8” Winters 4.11 low drag rear end
Longacre SMI gauges
XS power 16 volt battery and charger
BSB bearing gas pedal
Wildwood master cylinders and brake pedal
Second Generation Bert transmission
Butlerbuilt containment seat
Hooker Harnesses
One complete set of Hoosier 1350’s with 2 beadlocks and two non, all with cover provisions.
Can be priced many different ways:
Complete car minus motor and shocks: $35,000 obo
With motor, no shocks: $45,000 obo
With shocks, no motor: $39,000 obo
Complete car, motor, shocks, extra tires, Eibach springs, and other parts: $50,000 obo
Motor Alone:
PMI Blueprinted 604 Crate Motor
$9,500 obo
300 laps on motor since new
Less than that on most accessories
NeSmith seals, last NeSmith sealed PMI motor
Never turned over 6,800 rpms
Still in car, you can hear it run
Includes:
CV Products air filter base and flat top
R2C Competition Air Filter, pre filter, and breather covers
PMI Gas Carb
HVH 1” Super Sucker spacer
MSD distributor
Moroso Ultra 40 sleeved plug wires
NGK plugs
Schoenfeld headers with extensions, anti reversion mufflers, and turn downs
Stewart Components Stage four water pump
CVR fuel block off plate
Hendren two blade fan
Crate Insider Intake Manifold Water Line Kit (-20)
BSB Motor Mounts
Shocks:
Set of 2016 JRI shocks. Includes right front, right rear, left front, left rear behind, traction shock, and fifth coil. 30 laps on them. Paid $4,375 plus shipping. We will take $4,000
Extra Wheels:
We have three brand new in the box Weld Wide 5 XL 15 In Wheel w/ Beadlock & Cover, 5 In Offset for sale. Never opened $300 each.
We also have a one race used, Weld Wide five beadlock with cover with a 29.0 Hoosier 1600 mounted on it. We will take $375 for it. A non beadlock wheel with bolt in cover with a one race used 28.5 Hoosier 1600 on it. We will take $200 for it.
We also have three used non beadlock wheels with no cover option on them that are used with used 1350's already mounted on them. We will take $150 obo for them.
Email or text is the quickest way to reach me. robbymoore94@gmail.com or 865-659-2425. I can provide more pictures. I would prefer not ship the wheels
