Results 1 to 9 of 9
    Apr 2014
    294
    Default Gas LRF Shock on Axle clamp vs on Birdcage
    In simple what are the effects of running it on the clamp vs the birdcage?
    Batavia, OH
    13,676
    Quote Originally Posted by A ron View Post
    clamp bracket:
    Does less to keep car up on bars on corner entry. Any gas pressure and compression enhances lr tire loading when you accelerate off corner.
    Atomic - 2
    Apr 2014
    294
    Thanks MBR!
    Jul 2014
    399
    Axle wrap up will help load LR in transition when getting back on the gas, and not help on entry as MBR stated ....if you lift. I have never done it, but in theory, to me , it's an extra kick to induce body roll, more so with higher gas pressure,compression valving. Ever run shock clamped MBR? On a Super or a Crate?
    Apr 2014
    294
    We are running a crate.
    Apr 2014
    294
    my rookie driving style Definitely did not like it on the clamp haha
    Nov 2014
    488
    What were the actual effects? I've toyed with the idea of trying it?
    Apr 2014
    294
    Had a ton of fwd drive but pushed like a dump truck from the center to exit. When you could get back to the gas she hooked up. I'm sure it could be very effective with someone who had more driving experience and knowledge of the other changes to make when using it.
    Apr 2014
    294
    Also, I only tried it in hot laps. I may try it again when the track slicks off.
