Results 1 to 3 of 3
Thread: Pulleys
    Jan 2014
    9
    Default Pulleys
    Gonna be on oxygenated gas. What is the recommendation for pulleys.
    Oct 2007
    974
    we use a 15% reduction with serpentine set up
    commonly in days gone by 30% was common but I am assuming you are talking about a crate engine and they are typically installed in cars intended for much more power----which means the crate engine has it's tongue hung out most of the time causing elevated temperatures.
    spinning the fan a little quicker and moving the water a bit faster tends to help keep them stay cooler
    1 to 1 is common when using V belt but 15% has worked fine for us with serpentine
    Brad
    www.race-1.com
    Nov 2010
    112
    I have a complete KRC serpentine system if you are interested. It comes w/ Stewart aluminum water pump, 4" water pump pulley, 3.5" crank pulley, KRC aluminum power steering pump w/ 4.2" pulley, idler pulley & bracket, all spacers, belt, bolts and hardware. We ran on a 602. I will take $500 for it.
