Results 1 to 12 of 12
Thread: Bottoming out
    Default Bottoming out
    Car hadling half way decent over on the right front but tearing up skid plates left and right. Even getting on the frame rails entering and ruining good runs. 2014 rocket blue. Rf 275# 3 spring rubbers. When adding reboud car wont get over and stay over so i dont have any traction in the center. Need some help/advice.
    Jun 2007
    228
    How much travel are you getting on the rf?
    Jul 2014
    455
    Can you run on a stack? Or put in a heavy bump spring to limit travel?
    May 2009
    1,336
    Have you upgraded to the raised crossmember for the blue? Pretty common problem unless it has the 2015 updates
    Quote Originally Posted by phenom08 View Post
    Not sure how much travel we are getting. Obviously too much but does anyone know how mich i can get before bottoming out?
    1,014
    If you do have a raised crossmember or a "newer" car in general with the raised cross member I typically find when I pack the rack full of mud the driver (myself) is too blame. When I overdrive and make mistakes like jumping out of the gas too hard then I notice the frame dig in.
    If the crossmember is not raised then get it raised, then blame the driver if that does not fix it.
    738
    You could also go to the drop snout spindles to give yourself some additional travel room.
    Jun 2007
    228
    We aim for 4" travel and usually never travel more than 4.25" and our skid plate still looks new. Sounds like your traveling too much
    Im just learning about this stuff but should i use the hockey puck bump stops and shims to stop my travel at 4" and get my load rate at 4"?
  10. #10
    Jun 2007
    228
    Yes you want to set your load numbers for 4" of travel
  11. #11
    Check your inbox buddy
  12. #12
    Jan 2012
    332
    I run stacks and bumps both and set it to about 2200 pounds at 4" but honestly man if you just lay off the brake pedal I think the problem would stop and you wouldn't have to worry about getting a cross member update etc. It's a little awkward to drive without it at first but after forcing myself to do it I haven't had the problem since.
