2014 MBH Mastersbilt, Engine, Shocks, Transmission.
2014 MBH Mastersbilt. Round tube chassis, complete MBH updated suspension front and rear. Winters magnesium center section 4:11 rear with REM polished ring and pinion, bearings. New tubes with WMF bearing birdcages. Has 5 race old Wilwood calipers, brake pads and braided lines. Sweet Mfg. rack. New braided fuel lines/fuel filter and power steering lines. Ultrashield full containment seat, New belts, collapsible steering column, New digital memory tach, BWRC wedge cell. PRC double pass radiator. 2 Weld beadlocks and 2 non beads. Car has a body on it, has dents and dings but could be raced as is. $11,500 no engine, trans or shocks.
Advanced Racing Engines 358 all steel Chevy engine. Full roller engine. Has 164 laps on it from new. High compression engine, 6" rods with dome pistons, Dart Platinum heads, REV hollow stem stainless steel valves 2.05/1.65, Port and Polishes, 3 angle valve job, screw in studs, Roller rockers with stud girdles, MSD Billet distributor 85551, Moroso 8mm wires, Stewart 3 stage water pump, Billet pulleys etc. Over 600 hp. Very strong engine. $7800.00
Bert Ball spline transmission. Has 3 races on it since having new clutches and seals installed. Works perfect, Bert Reverse mount bell housing, has been repaired professionally with no issues and reverse mount starter. Complete set up $1500.00
Complete Integra shock package by MBH. RF, LR are canister, LF, RR, 5th coil are all IDA double adjustable and LRF is compression adjustable. Comes with all hardware. $2000.00
4 used Weld 15"x14"x5" non beadlock wheels. Need polishing but in great shape. $300.00
If interested, call or text 434-531-1736
I wanna go Fast!!!
New Price for roller $10,500.00and engine $7000.00
Tags for this Thread
