Eldora, Lima, Mountpilier, Millstream Stock Car
Roller
Car is a Camaro / Nova front clip tubing the rest of the way back - 3 link rear suspension - spring on top of the rear end housing - all wheels 5x5 pattern - Brand new 26 Gallon fuel cell and new fuel line - one season old belts (keeping my seat) - new tubular upper control arms - car is set up with a mid plate - has gauges and switches installed also has brake bias gauges - adjustable wilwood brake pedal assembly with clutch pedal - removable steering wheel steering quickner and power steering pump - Howe floater 9” ford rear-end currently with .514 gear 31 splined axels - also has fire suppression system
Body was brand new at the beginning of the season but shows some wear … but is raceable - newer style Camaro nose and tail from AR Bodies - has a lightweight plastic late model roof from Allstar full firewall (not stock) that goes all the way across
Shoenfeld chassis headers - 3 speed Saginaw transmission -with quarter master 6” clutch pressure plate and flywheel with the hydraulic throw out unit - double pass afco radiator - all go with the car (keeping the battery)
Car will come with spares for all front end parts and has multiple spares for the right price - will also come with extra wheels and tires depending on the price - have many spare parts for this car just depends on what you want to
I will not finance - Cash is the #1 option and would rather sell but may consider trades plus - the only trades considered will be campers or hot rods or possible pure stock
This car was the 2006 Eldora stock car champion with Shaun Phillipi driving and was runner up several times in the years to follow - car was also winning races up till 2012 with Shawn behind the wheel - all set up sheets and paperwork will go with the car
Roller with spares $3500
You want to just add your motor hook up and go to the track (will leave the 17” Kirkey race seat and yellow top optima battery) and including the trailer (open trailer LED lights all new bearings this year with 5000 lbs winch and new battery storage box on the front full of spares tire rack that will hold 6 tires and the trailer spare) $6000
Contact: Wayne Williams (937) 689-8241 phone or text or on Facebook
