Car/Engines
Barry Wright 07 front end car has 20 nights
$5,500 roller
Add to the above trans, bell housing, starter, driveshaft $7,500
Add to the above hyper oil springs and a set of ( 6 )pro shocks rf&lr are double adjustable also includes two take up springs( fresh ) $8,300
Replace the above with a set of ( 4 ) integra double adjustable 1 rebound adjustable 5th coil
1 traction shock, canister mounts, shock covers, inflation tool, 2 take up springs $10,800 ( I will have freshened after sold)
Peterson Oil system ( pump, tank, lines)$1,500
355ci Je flat top, bullet roller cam, comp lifters, child's n albert rods, scat 43# crank, champ cv oil pan, 215 dart iron eagle heads, titanium intake stainless ex valves, titanium retainers. 450 laps sense fresh heads had a valve job 100 laps ago, but has been setting 530 hp range $5,500
362ci callies crank, Oliver rods, je pistons, Roller cam, dart 215 iron eagle, this is a destroked engine with an aluminum dry sump pan if I remember correctly it has a 4-7 swap cam. 250 laps sense built but been setting. 575 hp $9000
Not on here much text 276-620-2105
Trades possible
Sent from my iPhone
Tags for this Thread
