CT 525 with all accesories
CT 525 with 12 nights fuel/power steering combo rear mount pump, 6LS box, Wiring Harness, motor mounts, pulley Kit, $8550.
includes the following: Chevrolet Performance LSX Ignition Controller programmed with wiring harness; a KRC CT525 Component Package that includes Front Drive Accessory, Water Pump, Belt, Pulleys, Tensioner, Alternator, LS Motor Mounts, Cross-Over Vent Tube, Water By-Pass Tube, and Mounting Hardware; HTD Flywheel with Flywheel Bolts Oil Pressure Adapter; and an HVH 2-Inch Spacer.
