Results 1 to 5 of 5
Thread: Pierce modified
    Oct 2013
    21
    Default Pierce modified
    On a clamped car. Lr clamped. Is it necessary to have a lift bar and a pullbar? Looking for help thanks
    2,814
    No. ,you have to have the right pullbar if you don't run the lift arm setup from pierce
    Just need to install a pull bar with a brake biscuit on it and you're good to go. The pierce pull bar does not have it, so you do have to buy a different pull bar.
    Jan 2015
    1
    does the pierce pull bar use a spring or is it just the biskets. my car came with a lot of parts nothing installed. I have three pull bars but not sure which goes in. clamp lr also.
    Just a spring. The pierce pull bar doesn't have a brake biscuit or anything, that's what the lift arm is used for.
