bsb 3 way pull bar
so we went to the bsb 3 way and can not get the car to hook up. running g60 tire with a little crate engine. it keeps binding up the little sleeve just before the bushing cutting or travel down to an inch. so i'm sure its going solid. but can't get no help from bsb so has any one had this problem and have a fix for it. car blows the tire off on take off and out the corner. indicator shows it only moving the same amount before it would hit the sleeve. thanks for any info.
I found with a crate engine that I needed to take the biscuit out of inside and just use the spring. I am not sure what spring you are running. I played around with them until I found the one that worked the best for me.
