Stock Car Roller
Roller
Car is a Camaro / Nova front clip tubing the rest of the way back - 3 link rear suspension - spring on top of the rear end housing - all wheels 5x5 pattern - Brand new 26 Gallon fuel cell and new fuel line - one season old belts (keeping my seat) - new tubular upper control arms - car is set up with a mid plate - has gauges and switches installed also has brake bias gauges - adjustable wilwood brake pedal assembly with clutch pedal - removable steering wheel and Howe steering quickner - Howe floater 9” ford rear-end currently with .514 gear 31 splined axels - also has fire suppression system
Body was brand new at the beginning of the season but shows some wear … but is raceable - newer style Camaro nose and tail from AR Bodies - has a lightweight plastic late model roof from Allstar - full firewall (not stock) that goes all the way across
Shoenfeld chassis headers - 3 speed Saginaw transmission -with quarter master 6” clutch pressure plate and flywheel with the hydraulic throw out unit - double pass afco radiator - all go with the car
Car will come with several spares for all front end parts - comes with extra springs and shocks for different set up options- will also come with extra wheels and tires - all set up sheets and paperwork will go with the car
Roller with spares $3000
Trailer also available (open trailer LED lights all new bearings this year with 5000 lbs winch and new battery storage box on the front full of spares tire rack that will hold 6 tires and the trailer spare) $4800
Contact: Wayne Williams (937) 689-8241 phone or text or on Facebook
