Results 1 to 8 of 8
Thread: 62" Rearend
    Jan 2011
    170
    Default 62" Rearend
    I have a Rearend out of a sportsman/pro stock type car. The car ran nova lowers and I'm guessing that's why the rear is wide. It is set up with the metric mounts from medieval chassis already. Can I make this work in a stock car with stock metric lowers by simply playing with offsets? Or do I need to buy a shorter housing
    Sep 2016
    4
    It will work, I have done it, and ran ok with it. BUT, I found you can only tuck the tires in so far before the calipers get in the way, and I had to run some really deep front wheels, which worked ok, but the tires hit the frame when getting close to full lock. I would get a narrower housing.
    Jul 2007
    3,224
    Is it centered? I wouldn't use it if so, you don't want the rr out like that.
    Nov 2016
    Central California
    43
    i run a 62" rear3'' offsets in the back 2" offsets in the front. still had to space the RR out to keep the tires off the leaf springs. i dont understand how people run the 60" rearends..
    LEAF SPRING NATION!!
    Jan 2011
    170
    It is centered.
    982
    We run 62" centered on all our metric cars,,
    We build fast race cars,,not race cars fast!
    Jul 2007
    3,224
    Quote Originally Posted by newguy View Post
    It is centered.
    I wouldn't use it, you want your rs tires track lined up or rr 1 inch behind the rf
    Sep 2007
    511
    we run 65" centered with 4 off wheels, but full size Impala chassis
