Another oil pressure question
ok, I've got an electric drill on the oil pump shaft. Shoul oil be gushing out of thst hole? It's doing that with less than 20 lbs showing on the gauge. Thanks F-9
Why do you have 2 threads going for the same problem? As I understand you bought the engine used. Did you have the pan off? What prompted you to check the oil pressure, was there a previous problem?
yes oil will come gushing out,slow down the drill speed,all you are doing is priming the engine,just make sure you are going clockwise
www.raceidaho.com
