Results 1 to 4 of 4
    Default mastersbilt chassis ID help
    01529 was told it was a 2010 gen x but from reading up on it I belive it to be a smack down and maby older then a 10. It is square tube back to the 4 bar then round tube over the rear end. It's a really nice piece so I ant worried about being hurt on it just need setup info ride heights and stuff so Im not way off from the get go. I tried to call mastersbilt for like a week strait and even emailed them and no luck figure there covered up this time a year
    Jul 2007
    120
    There is another post a page over & someone said their 2008 was 1510.
    I think a gen-x will have an x at the beginning.
    Ride heights will depend on s-7 front end or standard smack.
    I seen that other post so I figured at best mine was a early 09 but how do u know if it has the s7 front end like I said I can't get a hold of mastersbilt so I'm still at a lost
    Batavia, OH
    13,634
    If not an aftermarket spindle, the s7 has a tag on the upper part of the body that reads "mastersbilt". The snout is also lower than on the standard snackdown. Best way to make sure what you have is buy new s7 spindles. It is a used car, you need to replace them anyway because you have no idea if they are straight.
    Atomic - 1
