Results 1 to 4 of 4
Thread: axels
    Default axels
    thinking about going to light weight axels from soild axels was wondering if it was worth the money to go that way?
    in a van down by the river
    1,893
    if you do scribe a line down the axle and replace when you see twist.
    Jun 2007
    796
    I would say that your money is spent better somewhere else. The weight you save on the axles will not give you any measureable speed difference. The same money spent on tires will. You will save 5 lbs, while the guy next to you is bolting 30 on the axle tube.
    The Strange Oval axles are, by far, the way to go. They alter the od of each axle so the twist of each side is balanced and they are a better material which allows more torsional wrap while outlasting all other axles. They are a little more money but you will see an increase in performance and longer component life by using them.
    Feel free to contact us with any questions or to order them.
    Brian Ruhlman
    Ruhlman Race Cars, LLC
    2132 Jefferson Road
    Clarklake, MI 49234
    517-529-4661
    www.brianruhlmanracing.com
    email: brianruhlmanracing@yahoo.com
