2015 Skyrocket
2015 Skyrocket Modified For Sale
IMCA 8CAR Chassis
Frankland Superlite quick change rear end with gun drilled axles
Swift springs
Four bar suspension with brake floater and Aurora rod ends
Wilwood brake/clutch pedal assembly with mini brake bias gauges and adjuster
Coleman needle bearing throttle pedal
Longacre stepper motor gauges and memory tach
Crane Ignition box with coil
Beyea header
8:1 steering box with Sweet collapsible / adjustable steering column
AFCO light weight radiator
Total Power TP-1200 12V racing battery
Fuel Safe 28 gallon fuel cell
No driveline, seat & belts
$14000
Call or text 320-510-1018
