Tony barker 434 18 degree 800hp sbc fresh $10,000.00
TONY BARKER 434 18 DEGREE 800HP DART LITTLE M BLOCK BORED 4.165 BILLET MAINS AND STUDS NEW CAM BEARINGS CALLIES STEALTH MAGNUM 4.0 USA CRANKSHAFT WITH BBC SNOUT STD MAINS AND STD RODS--OLIVER 6 INCH LARGE JOURNAL RODS-- CP DOME PISTONS WITH SMALL METRIC RINGS AND GAS PORTED-- ULTRADYNE ROLLER CAMSHAFT AND CROWER HIGH SEAT ROLLER OFFSET LIFTERS-- TAPERED PUSH RODS-- T&D PROFFESIONAL SERIES SHAFT ROCKERS-- GM 363 18 DEGREE HEADS THAT A (not a nice word)(not a nice word)(not a nice word)(not a nice word)SON @ HRD ONE IF NOT THE BEST DID ALL THEIR MAJIC WORK ON (ALOT) THEM AND THE BOWTIE INTAKE (NOT CHEAP) 2.16 TITANIUM INTAKE AND SEVERE DUTY 1.6 EXHAUST VALVES TOOL STEEL VALVE SPRINGS-- MSD DISTRIBUTOR -- FLUID DAMPER BALANCER -- ROLLER TIMING SET --ALUMINUM WATER PUMP & PULLEYS -- ALUMINUM KEVCO EXTERNAL OIL PUMP PAN OR ALUMINUM THREE SCAVANGE LINE DRY SUMP PAN TAKE YOUR PICK
OTHER THAN BLOCK AND HEAD CORES EVERYTHING WAS BOUGHT NEW 1200 LAPS AGO
MOTOR HAS BEEN FRESHENED WITH NEW ROD BEARINGS-- MAIN BEARINGS-- RINGS-- CAM BEARINGS -- VALVE JOB-- TOOL STEEL VALVE SPRINGS
FRESH AND READY TO GO !!!!!!!!
Dyno RESULTS 797HP ON GAS
I HAD BUT LOST BOTH DYNO SHEETS AND FLOW CHART ON HEADS IN MOVING SORRY
PLEASE TEXT FIRST 573-382-2034
$10,000.00
Reason: REDUCED
