Results 1 to 8 of 8
Thread: Gear oil?
    Jul 2016
    23
    Default Gear oil?
    What gear oil do you guys recommend? Do I need 50 dollar a gallon oil or can I just go cheaper and change more often? I'm not at trying to be cheap, just curious what different stuff guys are using.
    Nov 2012
    Wisconsin
    3,119
    Synthetic works best but you can get good results with a dino 80w90, too.
    Class of 2019
    Nov 2007
    509
    Q/C aren't as sensitive to gear oil as the 9'' fords.Any good quality oil will give good life.One thing that I found with the low cost oils (house brand type) is, they will give up or break down quicker and need to be changed more often.
    in a van down by the river
    1,892
    I run Lucas oil synthetic 80/90
    Had great luck with it over th years.
    Sep 2008
    431
    Mystik is pretty good stuff, can't remember what it runs anymore though
  6. #6
    490
    We ran Valvoline Synthetic. Found our gears were much cooler when changing them between hot laps/heat/feature. Never had a failure with it in a QC or a 9".
    SPark
  7. #7
    421
    weve run schaeffer's for a long time
  8. #8
    Feb 2012
    1,102
    I'm on the valvoline synth wagon too. But we always have added a full small tube of graphite moly powder to it.
    Great wear and smooth operation.
