Results 1 to 8 of 8
Thread: barrel spring
    Default barrel spring
    I've been seeing a lot more guys using barrel springs. what is the advantages of them? pro - cons
    Nov 2012
    Wisconsin
    3,119
    More room for the shock... less damage to the top.
    Class of 2019
    Less harmonics and straighter compression.
    Nov 2016
    Mira Loma, CA
    22
    Barrels allow for a lighter wire material and less coils versus the linear coil over. Creates a faster and more consistent reaction. Jeremy Queener Eibach Motorsports
    Are guys running them on all four corners? Seen most on the right front
    Batavia, OH
    13,634
    Quote Originally Posted by n4cgrt View Post
    It won't hurt anything. I have used them everywhere but lf.
    Jun 2007
    3,123
    On rear shocks, be aware that you could end up with some interference issues if you run a piggy-back canister. I say on rear because those are the piggy backs that the canister is typically parallel with the shock itself. We had an issue once on the LR with an Ohlins shock. I noticed the new Integras have the canister spaced out quite a bit. Probably for this reason.
    Dec 2007
    116
    Matt 49is correct! Just found my Ohlins canister is very close to rubbing the hyperco 16" barrel. It is a piggyback.
