Results 1 to 13 of 13
    Nov 2012
    Wisconsin
    3,119
    Default Rear Axle Length Question... Paging MBR or ????
    My '96 Mastersbilt has a Winters QC. I've been s-l-o-w-l-y working on this car and this weekend I pulled the axles out so I can do some brake work.
    My question... right axle length 37"... left axle length 32"... is that much difference in length what I need? The right axle tube is steel and the left aluminum so I'm wondering if the right side was damaged and replaced with whatever the PO had laying around...
    This is a "wide combo" style rear clip (but it was a leaf car in the beginning). I have narrowed the tail to give more tire clearance for the right tire.
    Paging MBR...
    Class of 2019
    Nov 2012
    Wisconsin
    3,119
    Could be that the right side was lengthened to keep from damaging the RR tire... common for the era i have been told.
    I think I'll measure the front track and see what we have up there...
    Class of 2019
    Kansas
    1,939
    Quote Originally Posted by Krooser View Post
    Paging MBR...
    Measure the tube lengths, just cause the axle in it is ## don't mean the tube is the right length for that axle.
    Batavia, OH
    13,634
    I second what billet said. A lot of those cars had 32/36 axle setups. I think we had 32/37 for axles with no spacer bolt. One axle was ground just a touch.
    Should be 33/35 for the other smack down setup. 34/35 is gen x as far as I know.
    Atomic - 1
    Jun 2007
    3,123
    Quote Originally Posted by MasterSbilt_Racer View Post
    Correct...
  6. #6
    Interesting...
  7. #7
    Jun 2007
    3,123
    Quote Originally Posted by collateralDamage View Post
    Interesting...
    How so? 34/35 is standard for a GenX car.
  8. #8
    Nov 2012
    Wisconsin
    3,119
    I'll get out in the shop Saturday and do some more measuring. If it IS a 37" right side axle would anyone advise using a wider front setup?
    Class of 2019
  9. #9
    Batavia, OH
    13,634
    I would consider a wider front setup for that car anyway. But I would not leave the 37 rr.
  10. #10
    Nov 2012
    Wisconsin
    3,119
    I hear ya... gotta get out the tape measure then have somebody read it for me... 3rd grade was the best three years of my life.
    Class of 2019
  11. #11
    Nov 2012
    Wisconsin
    3,119
    Got the tape out... not quite 5" difference in the axle tubes measured from the inside face of the hub (at the bearing race) to the bell at the point where it meets the tube...
    Never paid much attention before but I have a gun drilled left axle and a solid right axle... I would bet, with the right tube being steel, that there was some damage at one point.
    Also took a closer look and see it's a mag rear not aluminum like I assumed... it has that grey oxidized look like a vintage set of Halibrand sprint car wheels. It has a 4.86 R&P... never checked it before. Got a dozen or so fine shavings in the housing under the QC gears... looks kinda normal to me.
    Now I have to add two things to my list... build a fixture to be able to stand the rear up on it's left spindle so I can service it and I'll be looking for an aluminum axle tube and a shorter gun drilled axle... the plot thickens.
    Class of 2019
  12. #12
    Oct 2008
    687
    Just bolt it to a wheel. Makes for a nifty stand.
  13. #13
    Nov 2012
    Wisconsin
    3,119
    That would work... I've used a agricultural disc about 18" in diameter as a base with a 5"diameter x 15" tall steel tube welded to it...
    Like my ex... cheap and easy. Works good for a grinder stand, to.
    Class of 2019
