Results 1 to 4 of 4
Thread: Crate Header
    Default Crate Header
    What's the best header for a 602 crate engine?
    Oct 2007
    974
    there is no "best"
    headers are a give and take
    1 design will take from one end of the power band and give to the other
    another design will do the opposite
    the trick is to add to one side and not "take" as much from the other
    1st order of business is the flange ---CORRECT header flange
    make sure your header flange is NOT covering any of the exhaust port and also make sure that it is not so big that it may lose a seal when put into use
    stay basic at first
    Brad
    www.race-1.com
    Oct 2012
    237
    Are the 602 ports the same as the 604 ports
    474
    Pretty sure the 602 takes a std SBC header flange, the 604 flange has bolts offset from std.
