Results 1 to 4 of 4
Thread: Arm location
    Default Arm location
    I have a rocket with the black front end - the set-up book calls for +5* camber on the left side - the a-arm cross shaft is located on the inside of the up-rights and i can only get about +2* of camber - should the cross shaft be mounted on the outside of the up-rights - nothing is bent - the chassis has been re-jigged at rocket and the ball joints and spindle have been checked - any help would be appreciated - thanks in advance
    May 2009
    1,336
    Just worked on one. They ended up changing to the bent uprights i'm going to assume you have the straight uprights which is where the problem lies. Its probably about a 2003 I'm guessing?
    Just shorten the lower control arm. If you are using the heim style.
    Jul 2014
    399
    This or use a 1/2" longer upper than called for.
