Swartz J-Bar?
What size rack does a Swartz car take, found that answer its 18.75" special size for a swartz car.
And how long of a J Bar?
35/35 rear end.
I would call Audie with the Chassis ID, on the tube in front of the driver where the steering column mounts. Audie has newer set ups sheets for the car. Audie's phone number is 740-820-2341
The J bar depends on if you have his pinion mount, and his frame mount, the pinion mount used is a custom radius as well as the J-bar itself is machined to fit around the yoke better.
