Results 1 to 3 of 3
Thread: I am stumped
    Default I am stumped
    We have been running same setup for years and has been very successful. Now the car is all over the place. Tight one lap and loose the next. The only thing I have come up with is that we have a set of tires the car does not like. This has happened in the past but we have not had a chance to test with different tires. Has anyone ever experienced this crazy phenomenon???
    Nov 2012
    Wisconsin
    3,119
    Check for loose parts... a arms, bushings, heim ends, bad tire...
    Class of 2019
    Post Falls,ID
    1,579
    Also check for bent balljoint
    www.raceidaho.com
