Latemodel Sellout 2 cars & 15 years worth of spares
269-2one4-642one Text or call
racer34v@yahoo.com
will ship at your cost
1 SET WILWOOD SUPERLITE "E" PADS NEW - $115.00 RETAIL - $50.00 SELL
1 SET DTC30 PADS NEW - $115.00 RETAIL - $50.00 SELL
2 NEW HAWK HR8000 ROTORS - $110.00 EA RETAIL - $50.00 EA SELL
1 NEW SNAP CAP FRONT WILWOOD HUB WITH ROTOR, BEARINGS, SEALS, GREASED AND READY TO GO - $125.00 EA -
2 USED TILTON STARTERS - $75.00 EA
1 USED MASON STARTER - $25.00
1 NEW CRANE HI-6RC IGN BOX, COIL, MOUNTED TO PLATE - $350.00 RETAIL - $175.00 SELL
2 COMPLETE SETS MSD REV CHIPS 7000-9000 RPM - $100.00 / LOT
2 NEW MSD 8210 COIL SELECTOR - $80.00 EA RETAIL - $40.00 EA SELL
1 NEW MSD MSD 8467 ROTOR - $10.00 RETAIL - $5.00 SELL
1 NEW MSD 8433 CAP - $40.00 RETAIL - $20.00 SELL
3 NEW MSD CRANK TRIGGERS $120.00 EA RETAIL - $60.00 EA SELL
3 NEW MSD DIST PICKUPS $35.00 EA RETAIL - $20.00 EA SELL
1 MSD TIMING LIGHT - WORKS PERFECT - $100.00
56 NEW CHAMPION C59Y PLUGS GAPPED AND NEVER SEIZED - $220.00 RETAIL - $110.00 SELL / LOT
52 NEW AUTOLITE 3932 PLUGS GAPPED AND NEVER SEIZED - $200.00 RETAIL - $100.00 SELL / LOT
64 NEW AUTOLITE 3933 PLUGS GAPPED AND NEVER SEIZED - $256.00 RETAIL - $125.00 SELL / LOT
1 NEW FLUIDYNE DB30416 OIL COOLER $285.00 NEW - $150.00 SELL
18 SETS QUICK CHANGE GEARS FOR 4.86 R&P - 4.86 5.00 5.08 5.22 5.32 5.42 5.49 5.55 5.67 5.79 5.88
5.97 6.07 6.12 6.21 6.34 6.48 6.71 - SOLD AS ONE LOT ONLY - $750.00
1 USED ROCK / LIFELINE 16V BATTERY - GOOD TAKE OUT - $100.00
5 NEW MISC ALLSTAR FAN SPACERS - $20.00 EA
5 NEW OUT OF BOX MISC FUEL PUMPS - $75.00 EA
1 NEW CARTER M7900G FUEL PUMP - $270.00 RETAIL - $125.00
4 HOLLEY DEAD HEAD REGULATORS - GOOD USED - $20.00 EA
18 NEW WIX 42096R 4" X 14" AIR FILTERS - $12.00 EA RETAIL - $6.00 EA SELL
50 QUARTS GIBBS XP6 OIL - $17.00 EA RETAIL - $8.00 EA ($400.00) SELL - SOLD AS ONE LOT ONLY
13 NEW MISC HEX ALUMINUM 4 BAR / TIE ROD SLEEVES WITH CHROME MOLY / TEFLON AURORA ROD ENDS - $30.00 EA
35 NEW MISC BARE HEX ALUM 4 BAR / TIE ROD SLEEVES 11" LONG UP - $10.00 EA
2 WEHRS BILLET J BARS WITH BEARINGS AND ADJUSTERS - $150.00 EA - NEW OR NEAR NEW
1 COMPLETE WINTERS QUICK CHANGE FOR BLOOMQUIST CHASSIS - 5 NIGHTS ON CENTER, NEW TUBES AND BELLS - $750.00
1 NEW COMPLETE SET BSB BEARING BIRDCAGES BLOOMQUIST / MASTERS - $750.00 NEW - $500.00 SELL
1 USED SET OF MASTERS WEHRS BUSHING BIRDCAGES - $100.00 / LOT
1 USED BLOOMQUIST 35 GALLON FUEL CELL WITH STRAPS - $250.00
MISC SHOCKS
1 JRI 3WAY RF - $650.00
2 OHLINS TRACTION - $300.00 EA
2 OHLINS LR - $450.00 EA
3 OHLINS RR - $450.00 EA
5 OHLINS FRONT - $450.00 EA
APPX 250 2-1/2" C/O SPRINGS - ALL RATES AND LENGTHS MOSTLY HYPERCO, A FEW SWIFT, A FEW AFCO - SOLD AS ONE LOT ONLY - $10,000.00 / OFFER
NICE CUSTOM MOTORIZED TIRE GRINDING AND GROOVING RIG WITH DOUBLE REDUCTION TRANSMISSION AND FORWARD / REVERSE - $750.00
VAN ALSTINE GROOVING IRON AND HUNDREDS OF BLADES - WORKS PERFECTLY - $300.00 / LOT
1 BRASWELL CARB 1.41 VENTURI - $750.00
1 BRASWELL CARB 1.48 VENTURI - $750.00
1 WILSON TIPPED CARB SPACER - $100.00
1 LSM VALVE SPRING PRESSURE TESTER JESEL / T&D - $125.00
1 LSM VALVE SPRING REMOVAL TOOL JESEL / T&D - $125.00
8 SETS BEYEA TRI-Y HEADERS - $500.00 PER SET
2 SETS SCHOENFELD TRI-Y HEADERS - $200.00 PER SET
7 MISC BARE UPPER A FRAMES DLM - $50.00 EA
3 UPPER A FRAMES WITH BALL JOINTS DLM - $75.00 EA
LIFETIME OF MISC A FRAMES - UPPERS AND LOWERS WITH AND WITHOUT ROD ENDS AND HOWE BALL JOINTS - $50.00-200.00 EA
BRAND NEW DART ALUMINUM BLOCK 9.375" DECK, 4.125" BORE, WITH CAPS AND STUDS - NEVER ASSEMBLED - $3500.00 / OFFER
1 EA NEW CANTON 7" DEEP LEFT TURN PAN SBC - $100.00
MORE PARTS TO COME AS SOON AS I CAN GET A LIST TOGETHER
2005 BLOOMQUIST W/2012 UPDATES - $4000.00 LESS SPRINGS AND SHOCKS, $6000.00 WITH SPRINGS AND SHOCKS
BODY RACEABLE AS IS
ROCKET ROOF
SWEET STEERING, COLUMN, COOLER, ETC
BSB BEARING BIRDCAGES LIKE NEW
WINTERS FULL OPTION 4.86 Q/C WITH LESS THAN 20 NIGHTS
HAWK ROTORS + DTC30 PADS LESS THAN 200 LAPS
RF SHUTOFF
AFCO RADIATOR LIKE NEW
QUICKCAR GAGES INCLUDING WATER PRESSURE
DIGITAL TEL-TACH
MSD6AL + COIL + AIRCRAFT TOGGLE SWITCHES
POEL 16 GALLON CELL INSTALLED
BLOOMQUIST 35 GAL CELL GOES WITH (ORIGINAL TO CHASSIS)
16V ROCK / LIFELINE BATTERY LIKE NEW
NEW SPARE FRONT BUMPER ASSEMBLY WITH MD3 NOSE COMPLETE
NEW SPARE FRONT BUMPER ASSEMBLY BARE
1 SET BEYEA TRI-Y HEADERS YOUR CHOICE OF FIRING ORDER LS, CONVENTIONAL OR 4-7 SWAP
OPTIONAL -
5 OHLINS SHOCKS WITH SPRINGS
2006 MASTERS BY MARS (UGLY BETTY) - $4000.00 LESS SPRINGS AND SHOCKS, $6000.00 WITH SPRINGS AND SHOCKS
BODY RACEABLE AS IS
ROCKET ROOF
BLOOMQUIST FRONT GEOMETRY, SPINDLES, ETC.
SWEET STEERING, COLUMN, COOLER, ETC.
DMI BULLDOG FULL OPTION 4.86 Q/C WITH 3 NIGHTS SINCE NEW
HAWK ROTORS + DTC30 PADS LESS THAN 400 LAPS
RF SHUTOFF
AUTO METER GAGES INCLUDING WATER PRESSURE
DIGITAL TEL-TACH
POEL 16 GALLON CELL
NEW SPARE FRONT BUMPER ASSEMBLY WITH NEW AR NOSE COMPLETE
NEW SPARE REAR BUMPER
OPTIONAL -
4 OHLINS SHOCKS WITH SPRINGS
1 JRI SHOCK WITH SPRING
Reason: sold items
Sold items removed. - Pics avail text or email.
Thanks
