Results 1 to 4 of 4
    Default Barry wright fuel cell
    Anyone converted a Barry wright fuel cell to top outlet to comply with the Lucas oil rules? Called Barry about it and they said they don't make anything to do it. Fuel safe makes a kit that looks to be the same thing but I'm not sure if they fit. Can anyone help me out?
    Nov 2012
    Wisconsin
    3,119
    Can you drill and tap the top plate for an outlet? I have an old 32 gallon cell laying around that some one changed like that... they used a plug on the oem bottom outlet.
    Class of 2019
    Feb 2016
    The land of Irma
    3,774
    Quote Originally Posted by Krooser View Post
    I was thinking the same thing. $20 at your local hydraulic/plumbing store should fix it!
    If its the plug they have a problem with, just build a new can, with the plug on the inside.
    Turn LEFT, Vote RIGHT!
    That might be my only solution. Really hadn't thought of doing it that way. Thanks
