Latemodel Parts - Team Sell Out - (Shocks/Rearends/Headers/Trannys/Misc Parts)
Shocks
AFCO – Control Shocks (1) - $50
AFCO – (2 sets) Silver Series Built By DPL Consulting for Rocket Car - $1250 Each
Rear End
Frankland 4.11 Rear-end (20 Races since fresh from Frankland) – Out of Rocket (has pinion plate and ladder bar mounts) - $800
Rocket TWM Grease-able Bird Cages (1-Set) - $200
Rocket Lift Bar (2-Piece) - $100
Oil Pump / Tanks
Pulley and belt for Oil Pump - $75
PRC Oil Tank (w/Dual Returns) - $275
Oil Cooler (Used) - $50
Transmissions
Bert G2 Tranny - $1600 (15 races on since new) (w/shifter&linkage)
Bert G2 shifter w/linkage - $65
Carbs
Stealth - 1.45 Gas Carb (Fresh) - $800
QuickFuel – 950 Gas Carb - $450
Moroso 1" Carb Spacer (4-Hole) - $30
2" Angled Carb Spacer - $50
Rocket Parts
Rocket B/F Spindles (Different Combos) – (2) Sets (New) - $160 set // (4) RF (used/good) - $40 Each
Front End Parts
Woodward Integrated Servo Rack - 4.19 - off Blue Front End Rocket (Fresh) - $350
AFCO Bolt In Upper Ball Joint (Low Friction) - (New) - $25
Mono Ball Studs - $10
Misc. Lower Control Arms - $30 each
Misc. Strut Rods w/ Heims - $20 each
Misc. Radius Rods w/ Heims - $15 each
Misc. Upper Control Arms - $40 each
New TMW 8.25" Upper - $100
Distibutors
DUI Crate Distributor - $300
Crane Digital Distributor w/ New Wire Set - $500
MSD/Ignition Parts
QuickCar 3 Switch Panel w/ switches and wiring - $40
MSD 6AL Box - $100
MSD 7 Gold Box - $175
MSD Soft Touch Rev-Limiter - $90
MSD HEI Chevy Cap - $25
MSD Rotor - $10
Drive Shafts
Steel D/S – 39” - $75
Wiles Carbon Fiber – Crate Drive Shaft - $350
Carbon Fiber 38.5" w/Yoke - $300
Headers
Beyea – Chevy Angle Port Tri-Y’s - $225
Wheels
Non Bead (7)- $75 each
Non-Bead w/ Tabs (3) - $110 each
Bead Locks (3) - $135 each
Radiators
AllStar - 19 x 28 Double Pass (New) - $100
PRC - 19 x 27.5 Double Pass w/ Water Pressure Bung (AN Top Hose)(Used) - $75
PRC – 19 x 27.5 Double Pass (Used) - $75
Springs
Misc. Coil Over Springs for Dirt Latemodel – Various Length/Rate/Brands - $20 each
Other Parts
AFCO Shock Canister Holders (4) - $40 Each or $150 for set
"Original" GM 4-Blade Fans (Used) - $40 Each
GM Water Pump (used) - $35
Steel J-Bar w/ adjuster - $50
PPM Travel Limiter (New) - $75
Vinyl Air Cleaner / Breather Covers - $20
4-way Lug Wrench - $20
Oil Cooler Tuber (2) - $10 each
Under Hood/Hood Scoop Cold Air Box - $75
Bert Balance Fly Wheel w/Belt Drive (2) - $35
Multiple Fan Spacers - $20 each
Used R2C Filters (14x4) - $40 Each
Used R2C Breathers - $10 Each
R2C Top Air Cleaner - $40
Air Cleaner Top/Bottom Kits (3) - $40
Wheel Foams (12) - $5 each
Call or email, open to OBO, package deals!
618-781-1522
618-973-1064
cschuster@tmcitransportation.com
