Results 1 to 3 of 3
    Default Newer mod driver setup 2017
    Have a metric 4 bar modified. Racing it first time this weekend. It has pinto spindles and nova lowers. Looking for experienced drivers input. Wanting to be forgiving and drivable. Lf-511. Rf-532. Lr-595. Rr-557. Left-50.3% 1106Right-49.6% 1089Front-47.5% 1043Rear-52.4% 1152Springs- lf-650. Rf-650 Lr-200. Rr-225. Lr-38lbs of biteLeft rear shock and spring behind. Right rear spring shock ahead. 7/16 long straightaway track with tight turns. Dry slick mostly. On the bars all the time or lapped real fast. Thanks guys & girls
    Sep 2013
    231
    It looks like you need more Left side and Rear percentage. I'd probably start with added a piece of weight to the LR to increase both along with LR bite. How much fuel when you scale? Driver out I assume. JMO
    Driver out. Half tank of fuel. 16 gal cell.
