rickybobby23
I can buy an all steel wet sump motor for very reasonable price to try to move up a class, but dyno sheet says around 450 hp. I know this is quite lower than most regular limited Late engines, but I wondered if it would be worth the buy just to get used to things, or if getting something more competitive would be best money spent. I don't want to be 3/4 of a lap down after 20 laps just because I'm that low on hp. I usually run a 1/2 or 5/8 mile track. Any suggestions are appreciated.
If you run small slick tracks you should be fine. Hell, I once set fast time at a local super show with a stock block, flat top piston, 23 degree head engine.
Atomic - 1
