Results 1 to 8 of 8
Thread: Valve Float
    Default Valve Float
    I'm chasing what seems to be a valve float issue. Everything was bought together so it would be like a matching set. Spring pressures were checked & set up (from what the machine shop told me). When I first ran this engine combo, the wrong gear was in the car & turning about 8800. The valves were floating pretty bad halfway up the straightaway. I'm now turning right 7500 & it sounds like a slight float at the upper end of the straight. Could it be possible that I have weakened the springs turning it up so much? Thanks F-9
    Sep 2007
    208
    hydraulic or solid , makes a differance
    Solid. 256/536
    Sep 2007
    208
    could be timing not advanced for that RPM
    It's at 34
    Sep 2007
    208
    36 - 37 for 8800
    Mar 2017
    7
    advanceable cam gear? head shaved?
    It does have an adjustable gear. Right now the cam is on zero. Was thinking about going 4 advance, but wanted to find the float issue before I did that. The head has been cut to the bottom of the intake studa
