Results 1 to 4 of 4
Thread: Holley 4412ct
    Default Holley 4412ct
    I've read quite of posts about the changes to make on these carbs, but didn't see anything about the accelerator pump size. It shows a 30 & 50. Going on a 2.3 short rods (5.2) .040 over, stock intake with no modifications, stock valve size & no porting, shaved down to intake bolts. running on 4/10 banked dirt. Thanks - F-9
    Sep 2007
    208
    350 cfm will be more crisp on your engine.
    Minden, Nevada
    1,027
    Use the 30cc pump and turn it down. Will help with pull over as you really don't need accell pump at rpms. You have enough vacuum coming thru the venturis to create good signal.
    178
    Turn it down? could you explain, I am not sure what that means.
    Thanks
