Results 1 to 3 of 3
    Default Accutech sportsman tach
    Ok, put in the stock TFI distributor with the V8 module. Would that module make the tach hand go crazy? I had the Pro Comp (that went bad) & MSD in it & it worked fine. If that's the case, how would you set the distributor? Thanks for any help..... F-9
    Take a look at this page if you don't have the instructions. http://static.speedwaymotors.com/pdf/47544385.pdf
    Not sure about the module. Maybe someone else will chime in.
    Hey man, thanks for the tip!! at least now how to re-set the tach & go from that!!! F-9
