Falcon Bell Housing Complete Setup with Starter $400
I have one Falcon bell housing complete set-up left.
This includes a bell housing, flywheel, all three coupler components to install a Falcon transmission, a starter and a flywheel shim.
The coupler has an HTD drive to run a rear mounted pump set-up. I have a coupler for a non-pump drive assembly if you prefer.
This comes with the actual starter designed for this set-up. The generic Falcon, Brinn, Bert starters will work, but not as well.
This set-up also comes with the pump mount on the bell housing.
$400 takes the complete set-up.
I have additional flywheels, couplers and starters if you need spares.
I have a ton of other stuff for sale at: http://wildincorporated.com/racing-sale/
You can contact me at 262-510-6246 (Text messaging is preferred) or 262-446-9747.
Email to kevin@wildincorporated.com.
Tags for this Thread
