Results 1 to 9 of 9
    Nov 2013
    25
    Default 604 Electrical Problem.. Need help!
    Have a fresh 604 (I had it freshened). It runs very well at idle and timed just fine at 4000RPM. The problem is when I took it out for its first hot laps, it popped and cracked like crazy while in the throttle, like a backfiring noise. What do I need to troubleshoot???
    Sep 2010
    29
    Try a new ignition switch
    Oct 2007
    974
    make sure you are rotor phased properly
    your magnetic pick up wires may be reversed
    if your distributor is locked (and it should be) this is very easy to check
    with the engine shut off align the timing marks (not zero) but what ever your timing is set at
    example: 34 degree mark on balancer with pointer on the timing cover
    now remove the distributor cap
    the rotor should be pointing directly at #1 or #6 (depending on stroke)
    if it is in between terminals then your mag pick up wires are reversed
    switch them and reset the timing
    problem will be solved
    if you have an old distributor cap ----you can drill a hole in it below the #1 terminal and actually check it with a timing light
    Brad
    www.race-1.com
    Nov 2013
    25
    One of the 3 magnetic pick up wires had broken loose. Thank you Brad, took me right to the problem.
    Jul 2014
    399
    Interesting, 3 wire pickup coil...???
    Nov 2013
    25
    Yes, it had black, red, and green going to a connector.
    Oct 2007
    974
    Oh Man,---that sounds like a ready to run distributor that does not use a box
    simply hooks to a coil and that is it----is that what you have?
    I have never heard anything good about those but out of curiosity I had to try one because of the simplicity---
    it never left the dyno----the thing had all kinds of issues and everything was new
    I switched the engine to a 6AL box and standard MSD distributor and it was instantly fixed
    Brad
    www.race-1.com
    Nov 2013
    25
    It's an HEI Distributor. Part number 8365. I am running a 6AL box. Would it be best to go ahead and change to standard?
    Jul 2014
    399
    With or without ignition module?
