Smackdown S7 Specs.
Need the Upper and Lower Control Arm lengths. Tie Rod Lengths and what if any chassis modifications are done to accept the new bolt ons. Have a customer with a cluster, and need to get him back on the right path...
Obviously you need the S7 spindles.
Left side is 10-1/2" upper, 16-5/8" lower.
Right side is 8-1/4" upper, 18-5/8" lower.
Ride heights are 3-1/2" on both sides (frame to lower)
Tie rods are 16-1/2" left and 18-7/8" right.
Different schools of thought on how to adjust toe but I set bump steer on right side and static toe with left.
