Results 1 to 16 of 16
    Default Turd on restarts
    604 with holley ultra hp carb. 650 cfm stock carb. Msd 6al box and dist. 34deg timing locked out. 6 to 7lbs of fuel pressure. 6.5 power valve and 72 jets front and back. I get ran over on starts. It doesn't bang or miss or anything. Just real lazy. But then takes off like a bat outa hell and runs great. What am I doing wrong or missing with this thing?
    Jun 2007
    1,047
    You've just discovered why people buy good custom built carburetors for the crate engines. There is a big difference.
    Jul 2014
    399
    What fuel? I hope you don't buy it from the track...some like to blend to increase profits!
    Everyone is running the holley ultra hp carb around here. That's why I bought it. I run the Sunoco 91 rush series fuel. Everyone has to run it or the Sunoco 110.
    Jul 2014
    399
    Put the 110 in it, from a sealed drum........and put the 91 in your lawnmower, JUNK!
    Funny thing is, a lot of people are bitching about the 110 right now. They are stumbling on the starts with it right now.
    Mar 2017
    Deep South
    65
    Check the basics. Are you sure you dont have a blown power valve that is moving way to much fuel all the time, which would make it really rich? Are all the air bleeds clean? Are the accelerator pump arms adjusted correctly? Which accelerator pump cams are you using?
    I just put a new 6.5 pv in it. But I've gotten bad new parts before too. I have no clue with anything else. Air bleeds "look" clean. I guess I may just pull the carb and send it back out maybe.
    Jul 2014
    399
    Quote Originally Posted by Porterracing2 View Post
    From a sealed drum is the key!
  10. #10
    Ya. I guess I don't know where it's coming from when they are complaining about it but at this time I can't budget a drum of 110 into my program. Just getting started back into the crate deal after an awesome divorce. Smh.
  11. #11
    Jun 2007
    1,047
    Stumbling on starts and re-starts is common for those carbs on crate engines. If everyone is running them you'd have a good advantage with one that is actually perfect on a crate engine. Fwiw.
  12. #12
    Jun 2007
    3,123
    Send it off to someone who understands the fuel curve demands of the engine that you are running, the fuel you are running, and the weight of your vehicle. It's money well spent. JDR is very good but there are others out there like Willy's and Stealth that do good work.
    Quick test for blown power valve is to close up your idle mixture screws with the motor idling. If it stays running with all of the screws closed, it is likely a blown power valve. As mentioned though you would also be suffering from a very rich condition which will quickly foul plugs.
  13. #13
    Oct 2007
    974
    I agree with all suggestions here and emphasize what LR tire changer said in his suggestion
    "check the basics"---fuel pressure and float level---and everything else mentioned
    try different restart tacticts---roll the throttle----power brake
    if your still not satisfied---as mentioned several times ---seek the help of the people who know
    don't overlook ignition either---grounds--rotor phasing--correct timing (was your balancer checked for TDC?)
    hope you figure it out soon
    Brad
    www.race-1.com
  14. #14
    Oct 2007
    974
    http://race-1.com/p-26182-what-shoul...timing-at.html
    pay special attention to the ***NOTE***
    Brad
  15. #15
    Jul 2014
    399
    Get with 4-5 guys that are having the problem and buy a drum for a night. The 91 is overpriced poor lawn cutting fuel...at best. You can't afford not to with how little the payback is for a poor finish.
  16. #16
    Oct 2007
    974
    the fuel may be his problem and I am no fan of the 91 but I think he should check some other things first
    to switch over for a night it would be 2 cars at best to split a drum---by the time you put 20+ gallons in the fuel cell to start
    Brad
    www.race-1.com
